L Lotsarocks New member Equipment L1500DT zen noh, 4' brush hog, ford 4' finish mower, 6' rock-landscape rake Feb 9, 2016 5 0 1 Midway, Ar. Apr 9, 2021 #1 What keys fit a ZL1500?
mikester Well-known member Equipment M59 TLB Oct 21, 2017 4,170 2,861 113 Canada www.divergentstuff.ca Apr 10, 2021 #2 A flat screwdriver? Other K keys? You can always buy a new key start switch, will come with a set of keys. Probably cheaper than a machinery master key set on fleabay. Reactions: 1 users
Thunder Fish Active member Equipment ZL2202DT-M Oct 21, 2017 164 45 28 100 Mile House BC,Canada Apr 10, 2021 #3 Lotsarocks said: What keys fit a ZL1500? Click to expand... Pull the switch and take it to a lock smith ? Reactions: 1 user
R Russell King Well-known member Lifetime Member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 8,075 3,177 113 Austin, Texas Apr 10, 2021 #4 Probably a key for a L175 or L185 would work. They probably use the same key but if you have to choose between them I would suggest that you get the L185 first.
billrigsby Well-known member Equipment L1500DT Too many implements, or is there such a thing? Mar 17, 2015 1,069 280 83 Florissant CO USA 8213' www.facebook.com Apr 10, 2021 #5 If it is the same as a L1500, yes the L175 key will fit. IF!
