Log Splitter
Big Kahuna
Kubota 2000 L3010 HST with Loader ,1992 B7100HST , 1979 B6100E & 2007 F2880
Dec 23, 2011
353
Homer City, Pa.
Just got done splitting some firewood with the old Kubota splitter and figured maybe some of you never seen one?
Big Kahuna
2,813
So have I,,, that thing makes me shiver with fright,,, I can only imagine how may people got twisted up in those things
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
Cool! I have the same splitter. It's really a productive tool and no hydraulics needed.
It's a tool, no different than a chainsaw, axe, torch, etc. If you are careless, you could get hurt.
Stubbyie
879
Midcontinent
Screws itself into the wood, right?
Used to be one like that on the market that the user would jack up one side of his vehicle rear, remove the wheel, and bolt the splitter to his hub. Crank the thing and feed the screw-splitter, split wood all day--faster than having to cycle a hydraulic unit.
I think lawyers got involved after some unfortunate events (!!) and that splitter is gone. Still occasionally see one go by at estate auctions.
2,234
Cool! I like your emergency stop mechanism. Your design I assume?
Big Kahuna
Dec 23, 2011
353
Homer City, Pa.
They did have a stop system for it, mounted to the rear fender. I just did a little rework of the idea. nothing like a big handle to grab when you need it.
Big Kahuna
4,383
I bought one of those new in bout '82. Used it a few times, and being 6'-4" and splitting hedge I decided it was too close to the ground for me. It's speed of splitting, functionality and safety didn't compare to the hydraulic splitter I built.
I stuck it under a work bench and actually forgot it was there. About 5 years ago I saw one for sale on Ebay. That's what reminded me I had one. I got it out, cleaned it and listed it on Ebay. Sold it for more then I paid for it to someone in Florida!
If I had to split wood with that thing, I'd quit burning wood! Not for me.
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
Good to know about. Since with my wood splitter I have had occasion where the wedge got stick and had to be backed out forcefully, does that beast ever get stuck in? If so what is the un-doing of that? Also, what is the emergency shut-off? Ignition key?
Big Kahuna
Dec 23, 2011
353
Homer City, Pa.
Never stuck it yet, and the emergency shut is just that, kills the engine.
Big Kahuna
MagKarl
L245DT
Aug 2, 2010
663
Olympia, WA
I've stuck mine many times. It will stall the motor when that happens. I generally resort to splitting the chunk off of the cone with wedges and occasionally a well placed saw cut.
4,383
MagKarl, your description is exactly why I put it under the bench. It made splitting wood MORE work, not less. When it gets bogged down and stalls you get to finish the splitting in a compromised position with it attached to the screwed in wedge. Then if you use your chainsaw to get it off you have to be real cautious not hitting the metal wedge.
If you're splitting straight grained pine, or some other soft straight grained wood it will work OK, but then you can pop those with a maul easier then getting this thing started and getting the wood out of the way for the next piece!
