Like road smoother than him ... unhappy people
jimh406
Kubota L2501 with R4 tires
Jan 29, 2021
3,003
2,372
Western MT
I found it humorous. I guess some people are just unhappy, or maybe he just had a bad Monday.
I was doing my last passes on the community road before the rains/snows get here today. I stopped to let someone pass. He didn't pass. So, I move over more. He didn't pass, but got out of his SUV.
I powered down and took my headphones off. I think I was expecting thanks/compliment/etc. That's pretty typical since I'm doing it with my tractor/fuel/my labor. Instead, he kicked some of the 2 inch or so size rocks out of the road. He says, "what happens to those rocks. They'll cut my tires." I said, "I throw them out of the road and sometimes others do." I said, "you'll got a flat on this road?" Of course he didn't. :D.
Then, he said, "are you turning up those rocks and what happens you run out of gravel from pushing the gravel out of the road". I said, "Those are from the road base. I'm pulling from the side of the road to the middle." I didn't explain how grader scrapers work.
Then, I said "you are welcome to maintain the road yourself". He said, "then people will go 80 by my house". "You like it smoother than I do". I didn't explain that there would be big rocks exposed if nobody maintained the road.
I did miss an opportunity since I've been trying to get the road straightened out from the damage done by the power company two years ago.
5,738
There are idiots and there are,,,,,,,,,,
11,429
I did miss and opportunity since I've been trying to get the road straightened out from the damage done by the power company two years ago.
I'll venture a guess that they are transplants from you know where. ;)😜:whistle:
Reactions: 6 users
Caden
1979 B7100
Apr 16, 2026
405
239
I've been in that situation for years.
Some people's lives must just be so miserable, what with being mad all the time.
I won't shut the engine off unless I know the person approaching to be friendly.
torch
Jun 10, 2016
2,899
1,153
Muskoka, Ont.
Put in a speedbump just before his house. ;-)
I also live on a private road. Mine is the first property from the municipal road and the private road bordering my place includes a curving hill. When I moved in 30 years ago it was just dirt, unimproved over it's 30 years of existence and crowned the wrong way from years of traffic. Treacherous in winter and a mud wallow in the spring.
Over the years I've brought in tons of rock and gravel, building a base, raising and crowning the bed, maintained with more material every few years as needed. All at my own expense and labour. All benefit and many neighbours have complimented it but nobody has ever offered to contribute. Same with clearing in the winter. Some have even hinted it would be nice if I kept going.
So I limit my efforts to the section bordering my property. If others are happy with their dirt trail, it doesn't matter to me: I don't need to go that way very often, it's a dead end. But if everybody maintained the stretch along their own property, the road would be passable year-round.
Last year one of the residents further down decided enough was enough and brought in several loads of gravel to try and improve things (no larger stuff for a base beneath though). After he was done he presented all the benefiting property owners with a bill for "their share" of the material cost. Boy did that move stir up a lot of controversy! Not the improvements -- the invoices.
Some people just want the benefits without the need to contribute.
Scm
BX23S
Sep 28, 2024
453
422
Missouri
I live at the end of our community road. I stopped grading/plowing it when my neighbors called the sheriff to accuse me of stealing 10 bales of hay. I had 300, didn't need another 10. Flat tires and missed days of work are going to cost far more than $60. I did fix it a few time after they listed their house for sale. I really wanted to help them sell. Its now off the market and they are stuck with me. :devilish::devilish::devilish: I no longer fix/plow the road.
torch
Jun 10, 2016
2,899
1,153
Muskoka, Ont.
LOL. Clearly the only reason for you to use your tractor to maintain the road is so you could use your tractor to steal their hay! You are obviously guilty as sin.
Question: Did you do it all in one trip? If so, did you tow the hay wagon behind the blade or hook the blade to the back of the wagon?
I laugh, but had a similar experience. My place is one of four lots subdivided from the original family's property, one for each child. Two put in their own driveways, the other just branched off from the original (now mine). Not so much as a right-of-way, he just did it.
That son used it seasonally. I used to clear out the branch to his garage so he could access his own tractor on the rare times he came up in the winter. I stopped when he died and his idiot daughter inherited the place.
The next year, said daughter and hubby showed up in the early spring and had to tromp through the snow to get to their place -- where they proceeded to call the police to complain that failing to clear their drive of accumulated snow somehow constituted deliberate obstruction of their access. The cop just shook her head and apologized when I showed her the property lines.
I told the neighbour if they ever tried a stunt like that again, I'd be putting in a fence. The husband tried to claim I had to give them notice. I said "I just did".
Scm
BX23S
Sep 28, 2024
453
422
Missouri
I could only fit one bale in bucket at a time, so it took ten trips. :ROFLMAO: :LOL:
I should of "borrowed" my buddies bigger bucket. could of done it in 5
KubotaHawg
L2800DT, LA463, Landpride Ī’Ī’1260, RCR1260, ZG222
Jan 9, 2022
194
412
NW Arkansas
Similar situation here to everyone above. Our transplants however are from a flat Midwest state and our 6/10 mile shared road is very steep with curves.
We have 4 others on this road that know how to drive steep gravel roads—SLOWLY—and are all very appreciative. In the two years Indiana Jones has been down here our road to their house is washboarded crap now. I stopped doing anything to the road from the top down to his house after politely asking them to slow down three times. At least the rough road slows them down a little. Past his house is ours and one more and ours is perfect—that neighbor has been there two months and has gone out of his way to ask what he can do to help already.
I’ll do anything to help a neighbor but if you’re unappreciative you’re SOL buddy. Sad, really.
Scm
BX23S
Sep 28, 2024
453
422
Missouri
I'm an ESCAPEE from MA/NH.
The natives are awesome in SW MO.
I thought I was safe here.
Mine MOVED from CT, which should explain everything.
I made it to 50 without ever having the cops called on me.
Of all the things I did do, it was something I didn't do.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,494
699
Richmond, Virginia
I had/have similar experience.
We had a family, one of the first buying a home first on the road (mid 1960's), they paid for gravel and regularly graded. It was great and I thanked them and offered to pay my share, which they refused. His wife passed and a few years later, then he passed. I put a notice in everyone's mail box that I'd get gravel and get some work done. Crickets. Ok. Trimmed some tree branches half broken and in the way. Some smiles, some dirty looks. Cleared the drainage ditches. The following year, I put the notice in the boxes again. Road had pot holes and was dirt. Told people (16 homes) in the note if money was an issue, to let me know. Crickets. I got $1,200 of gravel, spent two days spreading and crowning. After a month, 1/2 of the people paid. The rich ones, crickets. Put another note in everyone's box, listing everyone, thanking those that paid and reminding those that didn't. Well the rich ones spewed kittens! 'How dare I name them for not paying!!!' and 'You never said you were going to...' and 'We did not authorize this...'
Finally, after a few months, all had paid. Interestingly, the family of the guy that died, was the first to pay. The rich ones proceeded to bad mouth me and spread lying rumors. Fine. Not going to do it anymore. Then the complaints came 'Why is the road so bad, why aren't you taking care of it...'
No good deed goes unpunished.
KubotaHawg
Jan 9, 2022
194
412
NW Arkansas
I didn’t intend any insult to folks from other parts of the country, certainly not people from Indiana. She’s not very friendly but he’s a really nice guy. They just don’t know how to drive on hills and don’t take advice on how to do so correctly.
torch
Jun 10, 2016
2,899
1,153
Muskoka, Ont.
Substitute "state" for "city" and you might be on to something. Those that spent all their lives driving on pavement are less likely to understand what happens to a gravel road subjected to a heavy foot.
Amazon drivers are the worst around here. The pay must be crap because they seem to all drive clapped out beaters and drive like it's piece work. Very few of them actually take the time (or are able?) to read delivery instructions.
4,297
Loose gravel on top of a dirt road…..can teach a ā€œcity mouseā€ how their car can swap-ends and leave them in a ditch.
I quit maintaining the community dirt road when they all drove 50 mph on a dirt/gravel road. When one of them called to see if I’d pull them out with my tractor… told them my insurance wouldn’t cover t’he liability my chain might cause to their car… and gave them the phone number of the local wrecker.
( ā€œlocalā€ … is 20 miles away… it took a second day to get their car pulled out of the ditch.)
Most of ā€˜em drive much slower now.
5,738
Gawd why do these stories sound for familiar? Years ago when I was young, we had a camp in north in Penns woods, the PoPo showed up saying I had stolen a load of fire wood from a camp down the road. The guy that owned the camp was/is from Boston, he might still own it I dont know.
But I digress ,he had a sworn complaint that he saw me leaving his camp with a load of fire wood in a blue ford pick up. I didnt own a blue ford pickup, I had a green Jeep J10.
The PoPo say this guy was a jerk and he was sorry to bother me. To this day I dont know why his camp didnt suffer a case of Jewish Lighting, he was such a jerk to everyone on the road
torch
Jun 10, 2016
2,899
1,153
Muskoka, Ont.
Years ago my son lived on a small hobby farm, heated with wood. He'd bring in a load of logs into the lower field below the barn each year, cut and split it, stacked what he needed up by the house, stacked the surplus in neat rows near the barn. The surplus got bagged and wholesaled to local campgrounds and gas stations which paid for the load of logs and even a small supplement income.
One day (during the Covid shutdown when all the citiots fled to the cottage) he caught a guy red-handed in broad daylight backed into the lower drive filling his trunk with wood. "Oh I thought this was all free" "I didn't know anybody owned it" "I was going to come up and pay you after I loaded" were among the reported excuses.
My son made him unload and restack the wood he was stealing. Then put a chain up across the drive. I told him he should have put the chain up first and called the cops, 'cause I bet it wasn't the thief's first visit.
Skeets, I don't know why Grumpy the camp owner ID'd you as the thief. Maybe the blue Ford was pointed in your direction when it fled; some people can be quick jumping to conclusions. But I'm perfectly willing to entertain the claim that somebody stole his firewood.
5,738
Thats a fact Torch , Im not even sure any wood was taken, and to this day I still think he had some kind of hard on for us. I guess in all fairness we did party a lot there ,and maybe should have invited them to one of our camp fires, perhaps he felt left out.
