Land Pride WC1503 Chipper
Mandarin23
bx2680
Dec 22, 2024
WI
Hello All,
I have a Land Pride WC1503 in like new condition that is looking for a new home. This unit has a 12-30 hp rating and will chip 3" material. Very little use and works with the Land Pride quick attach system.
Retails for around $4500 and asking $2900 obo
Located In Green Bay WI
Happy to answer any questions
Thanks,
CWJ
BX2680, BX80 Advantage Cab, BX2830 Snowblower, SGCO554 Land Pride Claw Grapple
May 24, 2025
Ogden, UT
Interested in buying a WC1503 chipper. We have the same BX2680 tractor. Did you sell your chipper? Can you tell me how well it worked on your tractor.
bobnic
LX4020, BX2370, KX033, Ford 8N
Mar 7, 2025
92
79
Lakes Region, NH
I bought a LandPride WC1504 instead of a WC1503 chipper to use on my BX2370 and it works very well as long as I don't try to chip something larger than about 2-1/2". If you want to be able to chip branches with lots of Ys, the most important chipper characteristic is the chipper inlet opening. The WC1503 only has a 6"x3" opening whereas the WC1504 has a much larger 10'x4" opening. Obviously you cannot chip 4" diameter material with a BX, but the larger opening makes it much easier to feed branches thru.
CWJ
May 24, 2025
Ogden, UT
Thanks for your advice. I almost got a WoodMaxx last year but hesitated. It had a hydraulic feed; my BX’s PTO HP of 19 was towards the minimum requirement. Rep said it needed green material for lubrication; I’ve got 5 acres of old, dead, dry stuff from a wildfire in 2017. I backed out.
The ability to use the PTO was the initial appeal. Then, I could use my BX the other 3 seasons, and not have her be a hangar queen, awaiting snow. Sounds as if I should just rent a big chipper occasionally as I have 3-5” trunks.
You supplied just what I wanted-real feedback on the LP chipper using only a BX.
