LA211 Loader Issue
RC17
BX2200
May 28, 2026
Milford Ohio
Looking for advice on fixing my loader issue. I have a BX2200 with a LA211 loader. Occasionally the loader will not lift unless I move the 3 pt lever up. Once the 3 pt has engaged and I return it to neutral the loader then will lift. There is no issue with the tilt hydraulic. I did replace the seals in the lift cylinders recently but I don't see how that could have any effect on this.
7,016
Your pronlem is not with the loader. The problem is the down stream circuit is blocking the loader. Sounds like the 3pt control valve is not in neutral.
