I thought I would try the "simple" pin swap for the loader Boom that Kubota brags about. It came from the factory in the upper position for the 10% higher lift, but I wanted to swap it to the lower position (10% more lifting force). Followed the instructions, pulled the pin, tried to slide it in to the the lower hole without the boom (just to see if it would fit) but it was tight. So I greased it up, and tapped it in with a mallet. Now I cant get it back out, as there isn't a lot of room on the inside of the lift arm (engine side) to tap it back out.
Does anyone have a suggestion of a tool that would help remove it? Im thinking something like gear puller, but in reverse. Thanks in advance.
