L5030 HST Cab with Hydraulic Leak - NEED HELP SPLITTING
Alabama Tractor Pickers
Kubota L5030, Around 130 various IH tractors, Oliver, MF, A-C, Ford, Deere, etc.
Aug 1, 2023
Florence, Alabama
Can someone here help me in the procedure for a split of a cab L5030 tractor? It is 4x4 and I THINK it would be the seal on the propeller shaft leaking. I know I have to remove the custom skid plate on it, and split it at the clutch housing, but I've never split a cab tractor - not even a Kubota. Didn't know what I'm up against and what tools will be needed. I've attached a link to a Youtube video on it.
chim
L4240HSTC with FEL, Ford 1210
Jan 19, 2013
2,558
1,791
Near Lancaster, PA, USA
Welcome aboard! I started watching the video, but got too seasick to watch the whole thing :)
I'd suggest a workshop manual. I split a small open station Ford, but not sure I'd do well on a cabbed tractor.
Aug 1, 2023
Florence, Alabama
Sorry about that. I try to make good videos but I guess sometimes I get in a hurry. It goes into time lapse mode about halfway through so you almost made it! Haha. Where would I obtain the WSM for this tractor? Free download? Have to Purchase online?
woodman55
L6060HSTC, RTV 1100
May 15, 2022
1,050
868
canada
Go to you-tube and search "splitting the kubota". Buddy does a open station L5030. I think you will need to remove the cab.
Aug 1, 2023
Florence, Alabama
Thank you. The WSM says to remove the cab but not sure if it’s needed. Will look and figure out as I go I guess. The manual also says to remove all a/c components and sit out of the way. I’m not sure why that is required either but it might be obvious once I start working. I’m not worried about loosing Freon because it currently doesn’t have any/much in it.
