MY tractor when cool or cold, frequently starts fine but then abruptly shuts off. Sometimes (with the key still in the ON position) within a few moments of shut OFF, I hear rapid clicking of the fuel solenoid - sometimes just a couple of times, other times it will just chatter ON and OFF for several moments. Turning the key OFF and ON makes no difference - another words, the event is not associated with the turning ON or OFF of the key. I just need to wait for the fuel solenoid to engage again on its own, turn the key and the tractor starts right up. This problem tends to repeat several times until the tractor has reached normal operating temp, then it occurs only rarely.
I've replaced the fuel solenoid and now know the original was functioning just fine.
I've traced and checked the wiring harness for signs of cuts, damage or compromise. Everything appears fine.
I've checked the electrical relays behind the instrument panel. The one responsible for the fuel solenoid is also having the same rapid clicking, but I have replaced the relay switch and now know it too is NOT the problem. The new relay does the same thing.
I expect many of you can relate to my frustration in figuring out the problem. I'd appreciate your ideals on what to try next and I am concerned the problem will become progressively worse and lead to a day when I can no longer get the tractor to run at all.
