L3901 vs L4701 for 3k difference
shrimp92
Green, MS
Alright folks, I need advise.
Got a steep road that needs graded, using a land leveler I would like to get a 6' leveler. Would the l3901 Gear drive pull a 6' leveler well? All I have right now is a 16' ft 7K trailer. I am not planning to get another trailer, would the L4701 be too much for the trailer? Its hard to find specs on the loaders. This is my first tractor and would appreciate all the advise I can get. The l3901 would be more suitable for all my other tasks.
Tractor/Loader ONLY
QA Loader, 4x4, GEAR drive, R4 ballast tires
COSTS:
l3901 = $21,700
l4701 = $24,700
Note that they both come with the la524 loader
Guys that tried both tractors, what helped you decide, money? size?
MtnViewRanch
719
176
Lakeside Ca.
Tractor/Loader ONLY
COSTS:
l3901 = $21,700
l4701 = $24,700
The L4701 is quite a bit more tractor than the L3901. At about 500lbs heavier, all of it's ratings are bumped up about 500lbs also, that includes the loader which should be the LA765, not the LA525. Has std features that are options for the L3901.
I am not a Kubota guy, just looking at the info on the Kubota website.
For only $3k more, I would go with the L4701 if it were me.
Good luck with your decision.
speedymph1000
65
Alabama
Tractor/Loader ONLY
COSTS:
l3901 = $21,700
l4701 = $24,700
I bought the L3901 about a week ago and so far have excavated a 12' tall bank and graded it down so I could drive the mower up and down it, keep in mind this is in red clay, very hard to dig in. I think You'd be fine with the L3901 and use the 3k to buy more attachments. I got mine with LA 525 loader and BH 77 back hoe, R4 tires ballast filled, HST, 4WD, QA 66" bucket.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Welcome to OTT Shrimp. I would definitely go with the L4701 as you will find that the more tractor will be used from time to time. The increased height and weight lift of the L4701 loader is well worth it, not to mention the increased 3pt lift capibility.
TripleR
Sep 16, 2011
1,911
38
SE Missouri
I've found at least for me tractors are like sheds or garages, to get the right one go bigger than you think you'll need. I went shopping for a 35HP to supplement our M8540 and got a 50HP and was sure glad I did.
shrimp92
Green, MS
Fellows, I appreciate the advise. I too think bigger tractor is the way to go. My wife seems to say otherwise. Do any of you guys know how long and weight of the L4701 with loader?
ljjhouser
L4701, L765, Land Pride Box Blade
Jul 22, 2017
Kansas City, Missouri
Just for others who may read this post later. I have property just outside Branson Mo in the Ozark Mtns with a very steep road that sometime washes and seems to always require maintence. I considered both the 3901 and 4701, both with R4 tires. I was (and am always) concerned about performance on slopes. There is not a level place on my road and even one place which is very steep where the road turns 90 degrees. When I discussed this with the Kubota dealer, he told me that he would put them side by side and I should compare the footprint of both. I was suprised how much wider the 4701 was and how, even though larger, the CG seemed to be lower than the smaller tractor.
Look at them side by side from the rear before you decide. Best Wishes
