L3901 no start(fixed)
KHW59
L-3901 Brushhog, Finish mower, road planner, box blade.
Apr 28, 2016
60
Palatka Fl
My L3901 left me stranded when it would not restart on a dirt road. Could hear the fuel pump engage and had no Codes displayed. Checked the seat switch and all levers for correct positioning along withe switch. No issues found. Fuses were checked with a multimeter and Fuse 6 Starter relay had no power. Pulling the fuse showed it had not blown. Looking at the fuse holder revealed the issue; corrosion. Disconnected the battery and cleaned it out then spray it down with WD-40. Replaced fuse and it restarted fine.
Figured relating this here allows gives a heads up and searchable.
mickeyd
Mar 21, 2014
1,192
17
38
Guin, AL
Thank you for the post.
You are very correct about how this could save a lot of time for someone else. :)
Smokeless
3901/Loader/Rear Blade/Box Blade/LP Mower/Pallet forks IH M,,Cub & sickle mower
Feb 5, 2018
237
9
Southern Illinois
Thanks for posting. My 3901 is only two years old, but it resides in a non environmental controlled bldg and your post reminds me its close to treating my electrical connectors with dielectric grease. Appreciate heads up!!!!!
