L3800 coolant change, 4 quarts out six quarts in?
Desertdog
11
Las Vegas NV
Drained my coolant and flushed out the system until I had clean water coming out. When I went to fill it up, only took 4 quarts not the the 6.4 in the manual. Manual doesn't say anything about a block drain or anything about getting residual fluid out.
So 25% is straight water. Thinking about getting some test strips to see where I'm at. Anyone else run into this?
Desertdog
11
Las Vegas NV
Hard to say exactly as after the initial drain I started filling and flushing. The first one was still pretty green so I bottled it for disposal. I thought the same thing but after 4-5 flushes and adding new, getting hot and rechecking nothing went down.
Justasquid
L4240HSTC
Nov 2, 2020
74
31
You still had roughly 2 quarts of coolant ( water) in your engine. So if you mixed it at a 50/50 ratio, you are probably weak on freeze protection. It would be a good idea to test the coolant to see where you are If you’re in a cold climate.
