I have a 4wd model L3450 with shuttle shift with 170 hrs. Don't know for sure if I'm having a clutch issue or not... It seems that when the tractor was new, if I was on an incline or in a ditch, the tractor would either spin the wheels or would bog down if it couldn't climb out of it without engaging the 4wd lever. Recently I was in a ditch that I released the clutch completely and it didn't bog down, nor did it spin the tires. It just sat there. I know there is an adjustment for the clutch pedal, but is there a way to adjust the clutch itself? Is there something else that may be causing the perceived problem?
Thanks
DK
Thanks
DK
