F Finalist New member Equipment Kubota L3130 Aug 29, 2020 1 0 1 Nacogdoches TX Aug 29, 2020 #1 I need to replace the entire wheel hub outboard assembly for the right side. I found a deal on one pulled from an L3010. It sure looks the same in every detail. Does anyone know whether it is compatible?
W wdlanning Member Lifetime Member Equipment L3750, L4310, B20, Genie Boom Nov 7, 2016 224 11 18 philadelphia pa Aug 30, 2020 #2 Suggest you go to MB tractor or other web site and compare part numbers for the two models.
