L275DT wiring harness in bad shape
timsch
'49 8N, L275DT
Jun 11, 2018
172
Houston, TX
The wiring on my L275DT has always been pretty rough, but it always functioned well enough. Recently I found that the alternator/generator is not charging the battery, and it looks like the wiring may be the culprit. The wires to the alternator were patched up after getting too hot near the exhaust.
Can new wiring harnesses for these old tractors be bought anymore? I didn't find anything on a web search. If not, any references for good instructions on redoing the wiring would be greatly appreciated.
Thanks.
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
5,255
1,060
Williamstown Ontario Canada
I see wiring harness available from Messicks. Not cheap.
You would need to call them as I am not certain of the meaning of the stuff in the green box. Does 1.1 include harnesses 2 to 6... I do not know.
Converting you tractor to a one wire DENSO alternator may avoid many of your problem wiring as the voltage regulator is internal and there is only one wire to connect the alternator to the tractor.
Contact 007kubotaguy. He seems to be a good source of stuff for the early L series.
Dave
3,193
I bought a new harness for my similar but smaller size L185 from the dealer.
The indicator that Dave_eng references means that one part number can order all the parts or you can order them individually. You can get away with the 2and 3 only. They connect the alternator to the regulator.
If you can take the alternator and regulator to a repair shop they can be tested to make sure that they are working before you invest in the wire harness.
You could make your own harness if you’re into that but the connectors will be hard to get to match the existing but you can leave them out or use connectors that are handy.
Your regulator may have a three wire connector that is hard to find but the alternator repair shop can get it probably
whitetiger
Nov 20, 2011
3,846
2,239
Kansas City, KS
Dave
Dave, #1 consists of #2, #3, #4, #5 & #6. Price wise, it is the only way to go.
