I bought a L2501 with 3rd function setup (true 3rd function, not diverter valve). I noticed that the 3rd function valve only has 4 ports: 2 going to the front for the 3rd function, one goes to the loader PB port, and the other goes to the PB port on the front hydraulic block.
I think the line from the loader PB port is the high pressure side and the 2nd line to the PB port on the block is the return to tank/PB line. Is that correct? In this set up, there is no dedicated return to tank line? I always thought that the return to tank (low pressure) is separate from PB line.
Comments?
Comments?
