Frequently when I shift into R or sometimes another gear the transmission locks like it is in Park on an automatic transmission. I have to take it out of reverse, put it in another gear like 3/7, let off the clutch a little to move the tractor slightly, then shift it back into R.
It seems to be worse when the tractor is on level ground or the front end is higher than the rear end.
I have a loader on the tractor and sometimes when the front end is elevated, like digging into a pile, when I stop and put it in R, there is a grinding sound when I let out the clutch. The lever is tight but I can get it out of R, put it into a forward gear, move forward slightly, then put it back into R.
I have been afraid to take off the shift lever cover and see what is going on. I didn't want to mess something up or not be able to get things lined up and put back together correctly.
I am pretty mechanical but have never worked on a transmission.
Any ideas on what the problem is and how involved the repair is would be helpful.
