I think your picture is deceptive in the way the gauge looks like it is in between the valve and the filter. When I zoom in, the filter is actually placed in a line that enters the valve on the left hand side. That would be the pressure in port of the valve and the output from the pump.
That port must be connected to the tractor’s hydraulic pump output. The port that has the filter attached must be connected to the other pipe going to the three point hitch. That port is generally called the power beyond port if there is a power beyond sleeve installed. In your case that is the tank return being used for high pressure carry over (I think I have the correct name.). That line is the input into the three point control valve.
Your pressure is good enough but I think the tractor pump will get to around 2000 PSI unless it is worn out.
I think you can find the Work Shop Manual (WSM) here
Added on edit:
@NIW has beat me to the answer again. BUT I don’t think you will be returning any fluid from the tractor pump to that existing FEL sump. I am assuming you intend to abandon the front mounted pump and switch to the tractor pump. The tractor pump draws out of the transmission through a mesh screen so would empty the tractor sump quickly and overflow the FEL sump. The tractor pump would run dry and become damaged.
Added on edit:
