L2350 DT Wont Start
squatch87
1995 kubota l2350dt
Mar 10, 2015
Scottdale, pa, usa
I have a Kubota L2350 DT that wont start, just clicking at the starter. I replaced the starter and the battery has a full charge and the problem still exists. It started once then resumed clicking again. Any help would be greatful..Thanks
4,387
I would check electrical connections. Make sure cables at battery post are clean and tight. Then be sure the ground to the frame is clean and tight. You'll have to remove the ground at the frame to clean it good. Then cable to starter clean and tight.
2,167
thanks ill try those things this morning.
just because it looks good......doenst mean that it is good. Remove the connection - little steel wool or light sand paper and clean and then tight on the bolt/nut........
many times the connection to the frame via ground is the weakest link, btdt several times AFTER looking at everything else first!:)
check voltage too - clicking says that connections could be at fault OR the battery is weak ! How did you determine the full charge???
