L2250 coolant in oil sump
kubotal2250
canada
i went to start my tractor today and the low coolant level light came on. i shut the tractor off and checked the coolant resevoir and it was at the low mark. since there was no obvious extermal leaks i pulled the oil dipstick and the coolant was right to the top. im assuming ive got a blown head gasket. the engine has never overheated and always ran well. any insight would be appreciated. is it an overly difficult job to do? not sure how im going to get it in my shop as the loader is down and i dont want to run it and wash out the bearings. hopefully i can push it in in neutral somehow.
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
The radiator low too? If so, drain the oil leaving the plug out, and fill up the radiator. These commonly push a freeze plug out of the timing cover area. You will know because the coolant will flow right out and into the crankcase.
kubotal2250
canada
okay i will try that when i get a chance. so your telling me it may not be a head gasket? what are the chances there has been damage done to the engine?
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
“If” thats what it ends up being. Granted you didn't run it long prob low. The risk is wiping out lower end bearings due to lack of lubrication. This is common when the block is filled with water or bad coolant, and it freezes. Even a blown head gasket or crack wont allow the coolant to rush out as fast as you pour it in. Bad thing is, it is pretty involved to remove the timing cover.
kubotal2250
canada
Is there a way to verify if the bearings are shot? I'll drain the sump and hopefully it's not an absolute mud milkshake.
5,106
One reason the bearings and such don't get hit immediately is because the coolant / water stays on top of the oil and the pick up is on the bottom.
So your more than likely will get lucky with no burnt bearings.
Now how to get the loader up and off, just jack it up and off, your going to want it off to work on this.
kubotal2250
canada
Wonderful thanks I'm assuming I don't need to split the tractor in order to repair it .
kubotal2250
canada
I will try and get some pictures to post when I have time to work on it.
sorry for this silly question but im assuming if the other freeze pluges on the engine popped out or rotted that the coolant would leak out on the gorund. im assuming there are the 3 on the side of the engine the one under the timing cover you are talking about and one in the rear?
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
There are freeze plugs all around the block, and cylinder head. The one behind the timing cover is notorious for being pushed out. Engines come in all shapes and designs, so it is not necessarily the outer ones that pop. If it is the one behind the cover it will pour water out the oil drain as fast as you pour it in the radiator. Easy test and nothing needs to be disassembled to confirm. (#70)
kubotal2250
canada
i went to have a quick look last night and pulled the radiator cap and it is full to the top. im going to be pulling it into my garage in the next few days to drain and take the oil pan off. im hoping to diagnose it with out having to take to much apart. ive ordered a WSM and have a radiator pressure test kit and a leak down kit from a all terain vehicle project i did a few years ago.
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
If the radiator is full, it would seem you have another type of issue.
kubotal2250
canada
Yes that is what I thought as well . Perhaps a head gasket? The engine was always running in temp range I was always under the impression that head gaskets went from overheating.
5,106
Don't bother pulling the pan, just drain it.
I'm finding it hard to understand this statement
I pulled the oil dipstick and the coolant was right to the top.
How did you see coolant to the top of the dipstick?
And if there is coolant to the top, that amount to a whole heck of a lot more than just the overflow amount that it tripped the light at.
It's sounding more and more like you have a fuel or more likely a hydraulic fluid in the oil issue.
kubotal2250
canada
sorry for the misunderstanding.
when i pulled the dipstick after the engine had run i could see green on the dipstick. there was some higher up on the dipstick but perhaps that could just be cast off from when the engine was running briefly before i shut it down. i will make another look this evening now that it has been sitting. i will get some pictures of what i drain out when i get it into my garage. Murphy's law as now my clutch fork broke on my truck so i will have to take care of that first. when it rain it pours!
kubotal2250
canada
how would hydraulic fluid get into the oil ? im just trying to wrap my head around that
5,106
The hydraulic pump runs off of the back of the fuel cam, and if the seal on the back side of the hydraulic pump goes out , it will pump hydraulic fluid into the engine. The amount of fluid that is moved depends on several factors.
This is not that bad of an event because hydraulic fluid is essentially the same as motor oil with more additives.
