I have a grinding noise when either right or left brakes are applied, and so I drained the trans oil and pulled the final drive off.
I removed the wet disk brake and examined. There is the odd small blue spot, so I think at some point this was driven with a brake stuck on by a previous owner.
It all looks functional and not metal to metal as I thought. No grooves or scarring present on the metal plates.
However, I have no specs on what the thickness of the brake material on the disk should be. I can't tell if this is worn to the point of being out of specified thickness.
Does anyone have a new brake disk to measure?
