Is there anything special about the transmission oil in the older kubotas?
The last guy that had it 6 years and never changed the transmission oils. So I figure it's about due.
Does the transmission use ATF, gear oil, tractor transmission oil like what you see in 5gal buckets at tractor supply or something special from the kubotas dealer?
The transmission does not appear to have sycronizers and I think that's the main reason for using thin oil like ATF.
Also same with my brush shreadder it hasn't been changed in a few years. When I dump the gear oil out I'm expecting it to be stinky, thick 80-90wt type oil.
Is that what should be in the brush shredded 90° gear box?
