KX 161-3 lower roller replacement.
Pyroduck
Kx 161-3
Apr 10, 2021
Washington state
Hello all just found a bad lower roller on a 2006 kx 161-3. I’m new to the heavy equipment game and just have a couple questions. Only one appears to be obviously bad, should I just replace it or do the other 2 and top roller? Other 2 seemed tight. 2nd major question is there a best brand option? Factory or I found a good price on a pentom brand roller. Thanks for your feedback.
2,365
I personally would try the Pentom option on my older KX41-2 if I needed a replacement. NOT a high tech item...As for how many to replace, I am not sure. If replacement requires taking the track off and looks time consuming, might be worth replacing any you question, if not cost prohibitive.
