I picked up a ZG227 which had thrown a rod for dirt cheap. It has about 1500 hours but is still in pretty dang good shape other than the deck needing a little work. Anyhow I could not find a replacement engine so I picked up a 26hp kohler (liquid cooled version) and I have been unable to actually turn the key and start the engine. Here are things that I have done trying to trouble shoot the issue.
Checked all safety switches (seat, PTO, park) all tested good and all connection were cleaned before plugging everything back up.
Checked all fuses which all were good
Inspected not uses portion of wiring harness and did not see anything that should keep key from cranking engine over. Only thing I really used off the actual engine harness was for the fuel shutoff and the starter wiring.
I have no clue were to go from here. I am often able to figure things out without a problem but i see no other areas that could be the problem. The mower was said to be working just fine until the rod went through the block. I do know when key is on the fuel shutoff opens up so maybe I am just missing something that is simple. BTW, I have searched everywhere for a wiring diagram but without any luck.
On another note, I had to move the engine back 2.5" due to the radiator and the pulley which is on the flywheel. This caused me to run into a minor issue which may be simple to resolve or may be a little more complex. I do not have room for the factor muffler to fit under the hood. Are there any compact mufflers which I could use or possibly a simple yet effective muffler design that i could build? I kind of want to keep everything under the hood.
Thanks
Mike
Thanks
Mike
