Kubota Model Number Advice ??
farmboykj
G5200 ; ZD326
May 16, 2016
Central, Indiana
Hello - I am new to this forum and seeking some advice on model #'s of a used Kubota tractor that I am going to be in the market for. I currently have 2 Kubota lawn mowers that are great machines but do not have a lot of experience with the model #'s of the compact size tractors. I am looking to replace a 1978 International Harvester 284 tractor.
Here is what I would like to have in a Kubota tractor: Preferably no older than the 90's ; 30-35 Hp. ; would like to find a model that used metal body components instead of plastic ; FWA ; Gear drive transmission; an open operators platform would be nice ; front end loader compatible.
The tractor won't see a lot of heavy use, maybe 10-15 hrs. a year. I have bigger farm tractors for the heavy work. Mostly taking care of yard work (no mowing); grading the driveway, etc.
Thanks for any advice that can be offered.
8,703
L3200, L3240, L3300, L3400, L3410, L3430, L3430, L3540, L3560
There is also some older ones that are still great models.
I would say find the tractor at the right price and then worry about the model.
Get it with a loader and in 4wd!
2,825
I agree with NIW - find the machine that fits your needs and pocketbook - the rest will take care of itself!
I would get the loader too - 30+ hp will leave a lot of smaller machines out - I know that you may be use to a large HP machine, but I will also tell you that the B series will do a lot and never reach 30 HP!:)
Your rear lift on your IH is around 2000 lbs......A B series will not be that much, the L series will get up there.
If all you want to is light grading, drive way etc - the B series will do all that and so much more, and it will be a smaller footprint to get in and out of those places you would never have placed the IH. :)
If you had the gasser - you'll find the little 3 cyl kubota's will sip the fuel!
6,565
Why are you replacing the IH 284? What you describe is just a bit more HP, but if you're using it 10-15 hours per year what difference does that make? Must be more to the story....
farmboykj
G5200 ; ZD326
May 16, 2016
Central, Indiana
Thank you for taking the time to offer some advice. By listing the different series and model #'s, this will allow me to search down the right path. Do you have any idea on the year when Kubota switched from metal body parts to plastic?
My IH 284 is a gas 2wd model. It is a great little tractor and even though I am an IH fan, I would like to find something a little newer with FWA and a loader. I am not sold on some of the newer compact tractors that Case IH has offered and pretty much made my mind up on a Kubota.
ttj49
B6100-DT
This might help. It lists the Kubotas by year and horsepower and you can find more info and specs on just about any tractor at this site....
http://www.tractordata.com/farm-tra...kubota/kubota-tractors-horsepower-sorted.html
Grandad4
Apr 5, 2016
381
125
Greensboro, NC
Don't think any of the L or B models ever had plastic body parts. There was one model of the little BX tractors that had plastic, but it was only out for a short while before Kub went back to all-metal on the BX like everything else.
