kubota magnum chains
LRP
202
canada
3/4 ton pickup chains , added cross links , 1/4 in x 4 in FB x 6 in long.
now I have traction. the straight chevron thread is much better than this
dog leg chevron.
upload a picture
2,755
Man I bet thats one bumpy ride,,, Good idea, keep us in the loop how it works out
LRP
202
canada
yes I have and I think it would work on straight chevron thread. my other bota had no problem with traction, straight chevron thread with screw in studs. these tires, no. I have screwed them out and might use them on my quad.
click image upload
erda
LX3310HSDCC
Aug 24, 2014
53
Alberta, Canada
Curious as to what size of tyres you have on your Bota, and what size of tyres the truck chains were for. Thanks.
coachgeo
Nov 16, 2012
2,460
32
Southern OH
Only issue I can see is if your using 4wd and get enough traction not to be slipping anywhere. These make your rear tire larger in diameter and by 1/2?, 1"? and throws off your ratios. Though maybe not off enough to make a big deal...... I don't know:confused:
LRP
202
canada
my bota tires are 8-16. neighbor gave me the chains and they were for a 3/4 ton pickup. I have a 80 yd long X 25 yd wide patch besides the house and
the first passes I use 5th gear and the windrows spill overs I use 6th gear.
4,853
I think your chain plate Idea was good, but why not chain sections instead of plates, faster install and less chances of serious damage in the event of chain breakage?
I went a slightly different route when I wanted to get massive traction with the B7100.
Studded snow tires with chains.
