Kubota L39 Mid Case
David Coetzee
Kubota L39 TLB
May 13, 2021
Bloemfontein, South Africa
I have a Kubota L39 that I need to split the Mid case (Fig C401 in the parts list) from the gearbox I have removed all the bolts and nuts around the mid case but its still not splitting. Any advice on how to proceed?
The previous owner removed the 4x4 drive and I want to replace it.
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
You make it through the sealant yet? A slight elevation change usually helps. Look around the casting, there are pry points so you don't have to hit the flat surfaces. I take it you spoke to the previous owner on how/why the removed the 4wd...
David Coetzee
Kubota L39 TLB
May 13, 2021
I have managed to pry the casings loose from each other but it only moves a little bit. Feels like there is something preventing it from coming apart, I just cant find what it is. I cannot get hold of the previous owner unfortunately.
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
So your splitting from mid case to rear transmission?(c420)
Or clutch housing to mid case?(c401)
kubotafreak
Sep 20, 2018
1,022
374
Arkansas, US
I haven't worked on that model specifically, but you may need to remove the pto valve on the side of the mid case first.
rbargeron
Jul 6, 2015
1,149
219
western ma
Looks like there should be 6 studs plus 3 bolts holding them together? Don't have a WSM - wondering if there's anything inside the bottom trans cover that needs releasing? Looks like the bearing holder stays with the trans.
4,837
1,591
there's a little pipe inside behind the pto valve as I remember. Pry on the cases hard enough and it'll bend/break the pipe off. That's what I did. Not saying that's the correct way, just the way I did it--because the japanenglish service manuals don't tell you about it.
