"Battery Voltage
1. Stop the engine and turn the main switch off.
2. Connect the COM (-) lead of the voltmeter to the battery’s negative terminal post and the (+) lead to the positive terminal post, and measure the battery voltage.
3. If the battery voltage is less than the factory specification, check the battery specific gravity and recharge the battery.
Battery Terminal Connection
Battery voltage
Reference value
More than 12 V
1. Turn the main switch on, and turn on the head light.
2. Measure the voltage across the battery’s positive terminal post and the positive cable terminal, and the voltage across the battery’s negative terminal post and the chassis.
3. If the measurement exceeds the factory specification, clean the battery terminal posts and cable clamps, and tighten them firmly.
Potential difference
Reference value
Less than 0.1 V
Recharging NOTE
• The factory-installed battery is of non-refillable type. If the battery is weak, do not charge the battery but replace it with new one.
• When the battery is being activated, hydrogen and oxygen gases in the battery are extremely explosive. Keep open sparks and flames away from the battery at all times, especially when charging the battery.
• When charging the battery, ensure the vent caps are securely in place (If equipped).
• When disconnecting the cable from the battery, start with the negative terminal first. When connecting the cable to the battery, start with the positive terminal first.
• Never check battery charge by placing a metal object across the posts.
Use a voltmeter or hydrometer.
1. To slow charge the battery (1), connect the battery positive terminal (4) to the charge positive terminal and the negative (2) to the negative, then recharge in the standard fashion.
2. A boost charge is only for emergencies. It will partially charge the battery at a high rate and in a short time. When using a boost-charged battery, it is necessary to recharge the battery as early as possible. Failure to do this will shorten the battery’s service life.
3. The battery is charge if the indicator display turns green from black.
4. When exchanging an old battery for a new one, use battery of equal specification shown in table.
Directions for Storage
1. When storing the tractor for a long period, remove the battery from the tractor, adjust the electrolyte to the proper level and store in a dry place out of direct sunlight.
2. The battery self-discharges while it is stored. Recharge it once every three months in hot seasons and once every six months in cold seasons."
