B bretkissick New member Equipment Kubota L235DT Oct 24, 2021 4 0 1 62 Florida Dec 5, 2021 #1 Does anybody know the thread size of this nut? #11 in the picture
R Russell King Well-known member Equipment L185F, Modern Ag Competitor 4’ shredder, Rhino tiller, rear dirt scoop Jun 17, 2012 4,606 975 113 Austin, Texas Dec 5, 2021 #2 On my L185 it was 3/4 inch and regular thread pitch (not 100% sure on pitch). There may be a pin (#9 in lower part) in the upper end also. There is a hole in the #7 center part to drive pin out if the pin exists. One thread is also left hand but I think that was the lower section.
W wendol Active member Lifetime Member Equipment L3800 HST Feb 5, 2014 190 37 28 80 North Tx Dec 6, 2021 #3 I have that nut (same part number) on my L3800....definitely left hand threads, but have never able to determine the exact size. I was hoping to convert it to some type of ratcheting set up.......but has not happened so far!! Last edited: Dec 6, 2021
B bretkissick New member Equipment Kubota L235DT Oct 24, 2021 4 0 1 62 Florida Dec 6, 2021 #4 Russell King said: On my L185 it was 3/4 inch and regular thread pitch (not 100% sure on pitch). There may be a pin (#9 in lower part) in the upper end also. There is a hole in the #7 center part to drive pin out if the pin exists. One thread is also left hand but I think that was the lower section. Click to expand... Thank you for the reply!
B bretkissick New member Equipment Kubota L235DT Oct 24, 2021 4 0 1 62 Florida Dec 6, 2021 #5 wendol said: I have that nut (same part number) on my L3800....definitely left hand threads, but have never able to determine the exact size. I was hoping to convert it to some type of ratcheting set up.......but has not happened so far!! Click to expand... Thanks Wendol for the reply!
