Hi, I'm new here. I was hoping someone might be able to give me a few pointers.
I recently inherited a Generator with the Kubota D1005 Engine. The engine has been sitting a few years and it doesnt want to start. It only has around 3000 hours.
To start I emptied the fuel tank put all new fuel lines and fresh oil and filters. I pulled the injector hard lines and when cranking it shoots fuel out of the injection pump in each of the 3 corresponding fuel rail connections.
My problem is im not getting any smoke when cranking. Im not sure if its not getting enough pressure to pop the injectors or if the injectors are clogged.
When i crack the lines at each injector i get some bubbles but it doesnt seem like a lot of pressure. I have never owned one of these engines so im not really sure how much pressure i should be expecting when cracking the lines.
Any help would be greatly appreciated!
Thanks
Thanks
