Kubota B7000 oil fill levels?
Heikki 75
Kubota B7000
Jul 8, 2020
Finland
Hi.
First. Sorry for my english writing skills...
I have bought old but clean B7000 4wd and i have serviced it at last times.
Im not sure about front axle filling levels.
There is filling plugs with Red marking. There is also labels with japanese text. Thats imbossible to understand. But There is clearly numbers of volume.
Centre diff is marked 0,7l and hub gears 0,15l
So, i filled these by that volumes, But oil levels are not at plug levels? They are 15-20 millimeters lower than plugs. Is It ok?
I hope that someone understand what i mean?
Heikki 75
Kubota B7000
Jul 8, 2020
Finland
So, i mean that—> Is these Red marked plugs for check level or is them only for filling and correct levels are that marked volume?
freewheel3
MX5000DT LA852, BX1800D, B6000DT, B6200HSTD, B7100HSTD, L185, T1700HX, ZD1211
Mar 9, 2013
334
Alberta
You're probably fine using those volumes but I don't think it would cause any problems if you filled up to the level of the plugs. I've always filled to the plug level.
Heikki 75
Kubota B7000
Jul 8, 2020
Finland
Thank you.
I filled them more to the plug levels.
Hubs cames full by just about 0,03l extra oil.
Centre diff about 0,15l.
So, i think these volumes are intendet close to the plug leveles.
These Red marked plugs are intendet for check levels, i think So?
Is "intendet" correct word for this thing? :rolleyes:
