Kubota B2150 Hydraulic pump seal
Big Diehl
kubota B2150 and Kubota Z2100 mower
May 4, 2021
NC
I have a Kubota B2150 seal leaking on the pump shaft that drives the hydraulic pump. I wanting to know if the seal can be taken out and replaced without breaking the tractor apart?
Dave_eng
M7040, Nuffield 465
Oct 6, 2012
3,896
333
Williamstown Ontario Canada
Please be patient and provide more details rather than expect a quick answer.
What transmission does your tractor have?
Does it have a loader? If you have a loader, where does the loader get its hydraulic power?
Why do you think the pump seal is leaking?
Did the leaking start after some work or changes were done on the tractor?
Failed pump seals on comparatively modern tractor often follow some hydraulic incident where the pump was dead headed.
The pump on your tractor is a constant displacement style which means it has to discharge x .c.c. of oil for each revolution of the pump shaft or something breaks immediately.
The pump is mounted on the outside of the tractor so access does not require splitting the engine and transmission.
Dave
