Kubota 2670 mower gear box
BX25D Rookie
2011 BX 25LB-R (dirt work, snow, and brush hogging) & 2013 BX 2370 (mowing lawn)
Mar 21, 2019
293
387
upstate, NY USA
$1645.93 from Messicks for new. Plus shipping.
Note: You will have to call them, due to a serial number break someplace in the production run.
Here: https://www.messicks.com/catalogs/k...-discharge-mower/mower/a00403-bevel-gear-case
If I had a hard parts failure on a BX 60" deck gearbox, I would rebuild in myself, and if it was torn up real badly, I likely would replace it with a known good used deck gearbox. Simply due to cost. I'm pretty sure due to the "teeth count" on the internal bevel gears, the 60" deck gearbox is specific to the 60" deck. Meaning that a 54" deck gearbox might actually fit and bolt into place, but the blades would rotate at incorrect speed.
Have you checked here on the forum with @Mountainman?
Here: https://www.orangetractortalks.com/forums/threads/kubota-b-and-bx-series-salvage-yard.67416/
Send him a private message and see if he has a good used deck gearbox.
Hope that helps!
Can you tell us what happened to the gearbox? Like why you need a replacement?
Mountainman
L2501, B7100, B2710 B21, B1750, B2400, B7200
Jul 10, 2022
444
187
Attalla Alabama
mossycreekoutdoors.com
Hope that helps!
Thank you
