Found a 03 JD 4115 HST, The 4wd does not work, does not engage the front wheels. Is the JD HST as reliable as the Kubota HST? 2K hrs. Priced right if the 4wd issue is simple.
I had a slightly older JD 4100 model. That is a really good small machine. It’s a rebadged Yanmar and built better than the larger JD compact tractors.Found a 03 JD 4115 HST, The 4wd does not work, does not engage the front wheels. Is the JD HST as reliable as the Kubota HST? 2K hrs. Priced right if the 4wd issue is simple.
But the 4wd issue could be expensive (or not).I had a slightly older JD 4100 model. That is a really good small machine. It’s a rebadged Yanmar and built better than the larger JD compact tractors.
