Issues on the ignition switch
PerezVic_08
Kubota l3301
May 18, 2022
Mission
Hello. I've been having issues on a kubota l3301.. I was recently doing some work on it and I accidentally touched metal with positive wire from alternator and when I went to key switch to start nothing happened no lights at cluster no start! So I checked fuses and near the battery the 50 Amp was blown out, replaced with a new one the lights on cluster go on now but when turning over the ignition switch I get Absolutely NOTHING !! help me out fellas.
Pawnee
L2501
Jul 1, 2021
328
282
Ontario Canada
The 50A fuse held on long enough to blow something else.
If you have verified(not just looked at) all the other fuses then you will have to start checking connectors and wiring.
Since it won't crank but the lights are on you need to verify the start relay gets voltage(should make a loud click), and that the starter solenoid gets voltage.
