Hi all,
1st time poster and 1st time tractor owner!
Long post to provide the detail, but the key question is: Am I going to break this little tractor if I try out a flail mower that's probably too big for it?
I've bought a re-manufactured Kubota B7001 4WD Sub-Compact (which I believe is the Japanese domestic / Asian model no for a B7100). The seller had imported a few containers of re-manufactured B6001s and B7001s and implements from Japan to Australia 5 or 6 years ago and is selling off the last couple that have been in storage unused since then.
My package deal is with a FEL, 4'(?) slasher (what Aussies call a rotary mower / brush hog) and a flail mower. The clean (no implements) B7001 in the pics is mine. Please also see pics of a B6001 he's currently fitting an FEL (including Sub Frame) to - my FEL will be identical and fitted before collection. The seller has several older (original) Kubota B series, so we got to see the equivalent slasher in use behind his older, even less powerful 2 cylinder B6000 and it worked well slashing the same thick Kunzea (Tea Tree family) bush that we have all over our property.
On specs, the flail mower is too big for the tractor. I'd like to try it and see how well it works anyway, if I'm not going to damage anything trying. If it's too big, I'll keep it anyway as I can probably do a deal with a neighbour to use my flail mower on his larger tractor when needed for both properties. The seller said he imported some flail mowers based on demand, but has never used one and knew less about how they work they I did from my online research.
Key specs:
Kubota B7001 (fr TractorData website + B7100 Manual)
- 490kg (1080lbs) dry / no implements
- 17HP
- Slasher max rating 140kg (300lbs)
- Lower link max load rating 180kg (400lbs)
- Rotary Tiller max 180kg (400lbs)
- Backhoe max 270kg (600lbs), Sub Frame Necessary
- FEL max 227kg (500lbs), Sub Frame Necessary
Flail Mower: Lefa EFG-125 (Chinese)
- 230kg
- 24 Hammers
- Recommended 30-40 Hp Tractor
- https://www.lefa-cz.com/product/Flail-mower-EFG.html
I've seen similar spec'd flail mowers rated at 25+ HP and 20+ HP. I imagine (for tractor rating) that a flail mower is more similar to a rotary tiller than a slasher based on shorter overhang (so take the 180kg Kubota rating)?
Will the FEL subframe increase rear load rating on the tractor like the Backhow Specs? Obviously the FEL will provide good counter weight too.
So, do I try it or do I risk damaging the tractor by even trying?
Thanks!
Key specs:
- 17HP
- 230kg
- 24 Hammers
Thanks!
