Is anyone Monitoring Their Hydrostatic Oil Temps During the Past Few yrs of Elevated Summer Temps?
LFP57
LX2610 Land pride QH 10, BB1560, EA 55" Wicked Grapple, Top n Tilt, Wicked T
Sep 21, 2021
152
70
Another someone has been reading and relying on AI answers. :unsure:
No, not really, after watching a "tractor Time with Time" video, they were talking about one of his tractors running with higher temps and they installed a better cooler made me consider if it was an issue, especially those living down South. I simply asked if others had monitored this and did they make changes.
There has been some well-educated people that have replied respectfully and then there's the juvenile replies.
LFP57
Sep 21, 2021
152
70
The rule being quoted is based on the Arrhenius Rate Rule which predicts rate of chemical reaction as a function of temperature. The accuracy of that equation is well established.
In the case of applying that equation to hydraulic oil service life things get a bit murky.
The industry has arbitrarily established 140F (68C) as the standard for max service life. From there every 10C increase results in twuce as much thermal oxidation hence the "halves service life" prediction. That is not the death sentence most people attribute to it.
A more practical rule for mobile equipment is sump temps over 80C (176F) will have very real and practical negative consequences on service life. Likewise a high quality synthetic oil like SUDT2 will survive longer at 80C than a Grouo II based conventional oil. Intervals of higher temp increase oxidation but they dont immediately halve the service life.
As pointed out in the article I linked there are a host of other factors that play a role in service life. Dont get hung up on the "10C temp increase halves service life" and 140F metric. Its very deceiving language.
Obviously, you seem know what you're talking about and I thank you for the respectful reply. It may be a non-issue but I thought I'd ask.
7,016
First of all you need to understand the issue a bit better. Lets start with the physical chemistry
  1. Hydraulic and engine oils experience thermal degradation due to oxidation. Its a chemical reaction.
  2. The rate of oxidation varies with oil temperature. Thats true of nost chemical reactions and not just oil. Hotter temps increase the rate. The rule of thumb is the rate of a reaction doubles for every 10` C increase in temperature.
  3. The increase is basically constant across the entire temperature range of operation and nothing magic happens at 140F. An increase from 125F to 140F "cuts service life in half" just like an increase from 140 to 155.
OEMs establish a service interval based on many factors not just thermal oxidation. They do that by very robust used oil analysis and wear testing. They monitor the operation of the system and set the OCI based on measured changes in oil condition and system wear.
Hydraulic oils in mobile equipment commonly operate at temperatures well above 140C. High end construction and agticultural equipment have temperature alarms that operate north of 200F. Engine oils see temps in excess of 240F. The oils are formulated for those conditions.
Kubota knows this and designed their systems and established their OCI based on those conditions. Measuring temperature tells you nothing useful about their OCI recommendation. If you are concerned you would be better served sending used oil samples off to a testing lab. If you see oil thickening or excessive wear metals its a sign your opersting conditions are excessively severe and the OCI needs to be shortened.
Bearcatrp
Oversized Garden Tractor (aka BX1880) with loader, mower and 3 point
Mar 28, 2023
1,331
973
Minnesota
I don’t worry on stuff like that. I have insurance to deal with it IF it does damage my tractor.
Joisey
Kubota L47 TLB
May 31, 2015
227
151
Wild, Wonderful West Virginia
I look at it this way. Keeping the oil cooler won't hurt anything.
I rebuilt automatic transmissions for years. You could tell if the trans you were working on had a large air to oil cooler in the circuit by the lack of varnish in the trans, the lack of glaze on the clutch plates and how soft the seal rings were.
The transmissions in the best shape were those that were used at the drags. They had the snot beat out of them, but they ran the best fluid, deep sumps and an air to oil cooler that was in the 15K pound range. Shafts may be snapped from torque, but the clutches and seals were fine. THE most useless transmission cooler is the unit in the side take of the vehicle radiator.
William1
BX25D, JD X754 AWS Mower
Jul 28, 2015
1,420
624
Richmond, Virginia
My little tractor, the fluid has gotten so hot that grabbing a ram was a big mistake.I'm (almost) surprised the paint does not look burnt! SUDT in it.
I really doubt a 70 degree day or a 100 degree day makes much of a difference.
