If I were to buy a generator (450lb) can my bx2670 lift and move it?
cerlawson
rotiller, box scraper,etc.
Feb 24, 2011
1,067
PORTAGE, WI
I didn't see any lifting eyes on it. If you were to figure the bucket would lift it by lifting eyes for loading on a pick-up, the BX might not have enough lift height. 450 # would be about the same as lifting 4.5 cubic feet of earth. I think the BX would do it, but near its limit, depending on bucket model.
Tooljunkie
May 13, 2014
4,150
Most likely the cover can be removed. For service and for moving.
There needs to be some way to hoist and move/ secure them
Or they would all still be sitting in the factory.
450 isn't much of a lift even for a small loader.
Proper practice needs to be observed like on
Level ground and carry load low.
kubotasam
Apr 26, 2010
1,211
134
Alfred Maine
When I installed my Generac a few years back I moved it with my B7100. My generator had 4 holes one on each lower corner for placing the hooks from ratchet straps into. MY tractor moved mine easily. I don't see the lifting holes in the picture on the Home depot link you provided. There has got to be a recommended method of lifting.
OldMasterTech
KX057-4, KX121-3, L4630GST, RTV1100, AT60, T1700, T1560, 555E
Mar 28, 2011
30
Massachusetts
The lift holes are under the skirt around the bottom of the unit. Remove the skirt and use straps and homemade spreaders to lift. I just used forks but with a larger tractor.
You'll love the genset, I have that model and ran the whole house for 6 days during our most recent ice storm a couple years back.
Only complaint is hornets think it's a condo...
