I don't see where the backhoe manual states this?
so I can understand this
The 2 hoses going to the hoe are providing a constant 2000 psi or so at all times?
So I need to complete the loop if the hoe is off?
Also there s a valve under the tractor that the manual says should be changed from one state to another
IE turn from 90 degrees to 180 degrees if an implement is not attached , does this relieve the pressure?
The pump supplies a constant
flow. It comes out the hydraulic block on the side of the tractor, through the loader valve, on to the back hoe, through that valve, and then returns to the tractor. That circuit has to be complete at all times for the hydraulics to work. The pressure in that circuit varies with load and when all of the implement valves are in neutral is quite low..
The valve under the seat
disconnects the implement loop and redirects flow from the implement loop back to the tractor. As long as you have
ANY implement attached the valve under the seat should not be moved. Your loader counts as an implement and will not work if you move that valve. Same for the backhoe
Just connect the backhoe hoses together and all should work just fine. I could not find a manual for the BH7500 but here is the pertinent section from the BH75 manual.
