Ya, that would work for me too. And the wolves around here would probably prefer them tooHmmm a couple of sheep would do the same thing, and you can put them in the freezer in the winter,,, just sayin,,
I also have the same mower and it is a good mower but the issue I have is I do not bag with it and prefer to just let it side discharge as I use it mainly around my trees which are next to my front fence. so you lift the mulch plug and put on the plastic discharge chute, if anything touches the side discharge the cheap plastic discharge chute comes off and the mower will bog down because the grass gets a little taller then you can mulch. I finally got so annoyed by this that I finally just removed the mulch plug (it is spring loaded and snaps down real quick once the side discharge comes off which it is real easy to pop off). The mower works great without that dang burn mulch plug and simply rake the area and then run my GR2120 over the area.Here's some pics. And yes I bought seed and fertilizer to repair the damage my dog did all winter by the house. And yes the deck needs to be restained, LOL
