I have a problem with the lift arms and remotes not working sporadically. Sometimes after starting the tractor it may take 15-30minutes before they respond. Usually after they start, they work fine the rest of the day. Fluid and filters are good and loader lifts up and down fine all the time. Only lift arms and remotes giving trouble. This time, it has been down for 4 days. It did lift for a few minutes today but after I shut it down, they aren't responding again.
In addition to that, there is a (return) line from the oil cooler that is just plugged off under the seat and hear a constant clicking noise at the cooler that can be felt as a pulse on that plugged line. It has been that way longer than I have been working the tractor and curious where it needs to be routed.
Lift arms and remotes are my immediate issue. Thanks for any help
