Stmar Active member Equipment B2650HSDC May 23, 2017 932 48 28 Buffalo, Wyoming Jun 24, 2022 #1 I need to replace a hydraulic hose on my FEL. Will just operating it purge the air or do I need to do something more?
Henro Well-known member Equipment B2910, BX2200, KX41-2V mini Ex. May 24, 2019 5,983 3,200 113 North of Pittsburgh PA Jun 24, 2022 #2 Stmar said: I need to replace a hydraulic hose on my FEL. Will just operating it purge the air or do I need to do something more? Click to expand... That's the only thing I have ever done...
L loggin Active member Equipment MX4700 Sep 4, 2021 104 38 28 canada Jun 24, 2022 #3 Stmar said: I need to replace a hydraulic hose on my FEL. Will just operating it purge the air or do I need to do something more? Click to expand... Yes. Operating the hydraulics to maximum travel will purge the air.
Roadworthy Well-known member Lifetime Member Equipment L2501 HST Aug 17, 2019 1,647 528 113 Benton City, WA Jun 25, 2022 #4 I've never had to purge air with a simple hose replacement, just be sure to tighten the fittings and check for leaks.
Henro Well-known member Equipment B2910, BX2200, KX41-2V mini Ex. May 24, 2019 5,983 3,200 113 North of Pittsburgh PA Jun 25, 2022 #5 Roadworthy said: I've never had to purge air with a simple hose replacement, just be sure to tighten the fittings and check for leaks. Click to expand... Actually, unless you filled the hose with oil as you installed it somehow, you did purge the system of air when you operated the system afterwards. It was just a non issue…
Stmar Active member Equipment B2650HSDC May 23, 2017 932 48 28 Buffalo, Wyoming Jun 26, 2022 #6 Installed and no leaks and works fine. $15 seems like a good price, thought about getting a spare but tech said it was a bad hose and not common.
