Help
felhen
Kubota L3200DT, FDR1660 land pride finish mower, LA 524 front end loader
Oct 22, 2021
FL
When I start my kubota l3200 the battery light stays on at idle, but goes off when I give it gas.
Comes back on when at idle again.
Bmyers
May 27, 2019
3,170
3,660
Southern Illinois
Could be voltage regulator going bad.
4,055
yup... loose belt is my 1st guess..
a 'bad' regulator shouldn't charge due to increased RPMs
battery could be going 'bad'.
Without knowing the internals of the regulator, it's not easy to diagnose IF the regulator IS going 'bad' however since the light does go out, that suggests it IS working.
Nicksacco
Kubota L35 TLB
Sep 15, 2021
573
317
Bahama, NC
If belt tension is ok,
1-battery terminals or wires corroded?
2-you might try swapping a battery - car battery for example and see what happens.
3,833
If your Kubota uses gas, then you have a bigger problem than the battery light
johnjk
Apr 13, 2017
1,282
868
West Mansfield, OH
how old is the battery? Have you gotten it checked? Check power at battery powered off, at idle and at higher rpm. See if you are getting charging voltage to the battery.
4,383
That's what I was going to say, "Better step on the diesel". If all suggestions don't get you to the solution it might be easy to set up a mechanical gauge to see what the pressure actually is.
3,833
The common places to look for causes of the alternator light illuminating would be:
1) idle set too low
2) worn alternator belt causing slippage
3) belt is loose causing slippage
4) high resistance in the battery cables, clean and/or replace depending on condition.
5) poor ground refers to #4 for remedy.
6) alternator pulley is worn and the belt isn't riding on the sides of the pulley, but on the bottom of the pulley, but this is an extremely rare occasion.
If none of the above resolve your problem, remove the bulb, and the problem is solved. If the alternator fails, you will know about it when the battery goes dead.
Mlarv
BX23S
Jan 19, 2020
218
176
Crossville TN
1) idle set too low
Would black tape over the indicator work as well as pulling the bulb. I know it might be easier to do(-;
3,612
Amazing to me how many cars I’ve seen with black electrical tape over the check engine light. Out of sight, out of mind.
A slipping belt sounds like the most likely culprit and not a hard one to fix.
David Page
Jun 25, 2013
381
66
Dexter, ME
Yes, I thought battery terminals are cheap to check off the list. Just a film sometimes forms and is just enough to slow it down on charging.
Nicksacco
Kubota L35 TLB
Sep 15, 2021
573
317
Bahama, NC
I use this product on auto, motorcycle and my L35 and never have corrosion issues.
Check it out!
