Help with ZL600 crank in B6000
Jan 3, 2017
45
Boron California USA
Anybody have a good used crankshaft for a zl600 cheap .? Someone drilled the pilot bearing hole to over 1 inch an it's off center to boot . check out the picture!
Sent from my XT1609 using Tapatalk
3,174
Try taking the bushing out and see if the hole is actually centered in the shaft.
You may be able to machine a larger hole and shrink in a steel part to machine back to original size if it really is off center
You have a similar response in the post in BUY AND SELL FORUM so sorry for duplication of response- I hadn’t seen that post
