Hello, My SVL 90-2 started blowing fuses on the air conditioner fan last year and I would replace the 20amp "blower motor" fuse as needed. Recently when I had the same problem (No fan but compressor is kicking on), I discovered the fuse was fine, but the 10amp "compressor clutch" fuse was blown. After replacing the compressor clutch fuse the problem was solved- for a day. Same problem. No fan. I've tried replacing the cabin and outside air filters, cleaning the condenser, and the extremely hard to get to evaporator, with no results. I have also checked as best I could for obvious shorts and loose wires. Any help or advice would be appreciated.
