Help! Right Oil? Wrong fill hole
sdcarter00
14
Jesup, Ga
I think I accidentally out motor oil where transmission fluid goes! Have a 1 year old Kubota Bx23s! What do I need to do???
Sent from my SAMSUNG-SM-G925A using Tapatalk
thebicman
B2601 + BX2755HD + 50" box blade
Feb 2, 2017
337
100
Ottawa, ontario
Re: Help!
If you have any doubt I would drain the system, change the filter and refill with the correct fluid.
Kevin1
Husqvarna MZT 52, BX2380,FEL, Box blade, Landscape Rake
Dec 15, 2017
127
New Bern, N.C.
Re: Help!
Yes, drain and change filters right away. These things happen, just be glad you caught it.
sdcarter00
14
Jesup, Ga
Re: Help!
You wouldn't happen to know which filter, there's no Kubota dealer near me, unsure what cross reference with this filter.
Orangeglow
2015 BX2370
Jun 19, 2014
348
168
Prescott, Ontario
Re: Help!
Take the number off of your existing filter, and go on the net looking for cross reference numbers to other filters. Take the old filter with you to a parts supply store, and they should know how to cross reference it as well.
And don,t forget to pick up the correct amount and type of new transmission fluid as well.
sdcarter00
14
Jesup, Ga
Re: Help!
Thanks, that's why I wanted to know filter number, just make 1 trip to parts store, but need to buy filter wrench to get it off
Orangeglow
2015 BX2370
Jun 19, 2014
348
168
Prescott, Ontario
Re: Help!
Can you see the number on the stock filter ?Do you have a good oil filter removal wrench ? Can you snap a photo with your cellphone ? Don,t forget to get the proper type and amount of new transmission fluid as well. You might even want to upgrade to the better sudt type, which supposedly helps your tractor run quieter. Get yourself ready for a shock when you see the price. It is expensive, but from what others are saying, is worth the extra money for the better product.
sdcarter00
14
Jesup, Ga
Re: Help!
On my way now to get oil filter wrench
sheepfarmer
Nov 14, 2014
4,441
677
MidMichigan
Re: Help!
Have you got your owner's manual? This information is in there in the maintenance section. If you have an hst you want to stick with Kubota oil and filter for the transmission in my opinion.The new tractors come with SUDT2 in them. You can order online from Colemans or Messicks, or nearest dealer may ship you what you need. There seems to be less consensus that you need to stick with Kubota engine oils. More people think it is worth it to stick with Kubota filters.
sdcarter00
14
Jesup, Ga
Re: Help!
Yeah, gonna go to Kubota dealer tomorrow and get what I need! Thanks
rlcotter
BX23S Cab;3pt Blade;HLA Snow Pusher;BX Armour;HLA Fork;Ratchet Rake, Snow Edge
Mar 24, 2016
50
Ontario, Canada
Re: Help!
Hi SD.
I changed my transmission filter on my BX23S this weekend.
The transmission filter number is HHK20-36990.
Hope all goes well.
Les.
