Help needed for Meter Panel Repairs
UH46CREW
BX2670
Aug 10, 2020
Kansas
I have a BX2670D-1 with a dead meter panel. I have located the problem but without a real schematic of the PCB or even a photo of a board with all its parts I’m unable to make repairs. I have posted photos of the problem. It would be great if someone has or could get a working photo of same area and/or part info of missing part(s).
any assistance would be greatly appreciated.
ps: I have 50+ years experience in repairing PCBs so that’s not an issue...however the missing part(s) are.
AFC4243F-C619-40C0-871D-F2BB8918BE57.jpeg EC29C477-EC6D-4CFE-8585-D9130D50F224.jpeg
Jim L.
815
87
Here's a suggestion for widening the search. Post the Kubota part number of the panel assembly from your machine, just in case of a change between serial numbers. Also look for any manufacturing numbers on the printed wiring board. It appears to have lots of test points. So wondering if it is particular to BX2670 or the board is used on other machines. Might cross reference the panel assembly part number to see if other machines use it. Is the panel an Intellipanel?
4,033
have to ask, what's the OTHER side of the PCB look like ?? Hopefully it's just a 2 sided PCB, otherwise toy're in for some 'fun'.....
Assuming you have the schematic of the tractor, you can 'ring out' the I/O pins.
Either the cap blew to a short( water damage ?) or excessive current ( zener shorted ?)
I just 'play with PICs' these days to challenge the grey cells.
