Harden or not to harden pins.
Hugo Habicht
G1900
Jun 24, 2024
1,492
2,144
Ireland
Hi,
I am building a little garden trailer here that has a few pivot pins. I am debating now if I should harden the pins.
They will always be greased well and the trailer will never see a lot of work, so I think it should work with soft pins. It is a fairly snug fit, so concerns are that hardening will cause distortion.
What would you do?
5,061
Just thinking out loud here.
I would think that hardening would be best, but not really necessary from your description.
If its not going to see that much use, I probably wouldn’t go through the hassle.
Just my .02
6,886
Hi,
What would you do?
I would use inexpensive 1045 TGP shafting and never think twice.
11,610
Hi,
What would you do?
Are you talking case hardening only for wear resistance? Fun to do but as @TheOldHokie says there are easier/quicker/less fun ways to go about it with plenty of suitable materials. 4140 is a good choice too and readily available in various diameters.
I'm often on metalsdepot.com to look at material specs and cost and just ordered some 2-1/4"x.125" DOM tubing for a boat related project and ended up buying 3 ft from Amazon since it was way cheaper. The shipping charges can be brutal, and the local steel supplier can be way overpriced on some stuff. Not sure what options you have in Ireland for steel but I'm sure you can find material easily enough. You might even find something on Amazon.
10,622
I've seen your build pics.
You don't need hardened pins for your use, your actually better off not having hardened pins. ;)
10,622
Could you please explain why you think soft pins are better?
One concern I have is seizing if two soft materials move against each other under high load.
Because they flex and not just snap.
Your not putting enough force or movement on this kinds of pins for them to need to be hardened.
Just make sure you put a grease zerk and a grease grove on the pin any you will be fine.
Hugo Habicht
G1900
Jun 24, 2024
1,492
2,144
Ireland
Thank you for the reply!
Grease supply is taken care of:
