Atlanta Panther
Kubota L3200HST with Loaded R4 Tires, LA524 Loader and Quick Connect 66" bucket
So I am trying to grease the front axle support. I took out the breather plug like it tells you to do. I greased the front grease fitting and grease came out of the breather tube almost immediately. However, when I went to grease the front axle support grease fitting behind the axle I just keep pumping and pumping grease. I don't know where it all goes because its not coming out the breather tube. I finally stopped cause I want to make sure I'm not doing any damage.
Any ideas?
Thanks!
Any ideas?
Thanks!
