Gear transmission fluid
OrangeMopar
B7200
Aug 4, 2016
Stoystown
I'm having some confusion about the transmission fluid for my B7200D. It has a gear shift transmission and a front loader in a common reservoir. If this is the case I should be able to use universal tractor trans/hydraulic fluid, correct? Or does this only apply to hydrostatic transmissions? I have been reading that the heat trans can use 80w90 gear oil but thats ONLY without the loader from what I understand. Can anyone confirm this for me?
Sent from my K011 using Tapatalk
2,016
I have a L185 gear and used universal tractor fluid in it. I have no loader but the 3PH works well. The manual states 80w90 but was written before universal fluids were available.
You will be fine with a universal tractor fluid and probably be happier with the loader operation.
