Fuel Line I.D. (inner diameter)
Flintknapper
L2350DT
May 3, 2022
1,561
1,996
Deep East Texas
I am going to purchase some fuel line and also add a shutoff valve on my L2350 Kubota.
Anyone happen to know the I.D. of the fuel line or size of the barb fittings. Metric I imagine but I can find the nearest fractional size. Just don't want to remove what I have now until I'm ready to replace it (will order the parts).
Thank You in advance... if anyone should have the answer.
Flint.
2,104
I would try 5/16" = 8 mm
Orange4X4
L2350DT with loader , 52" Taylor Way , Ratchet Rake , Land Pride post hole
Aug 12, 2018
40
Concordia, MO
I bought some clear 3/8 hose from McMaster Carr that's OK with diesel fuel.
On Ebay I found a inline shut off that is OK with diesel fuel.
It's possible to get a 90 deg barb also. These auot shut off fuel as soon as you disconnect the connectors. Put mine on in 2019 not had any leaks .
COLDER PLC NSF
#PLCD17006 Inline Coupler,Acetal,Shut-Off,Barbed $12.68
#PLCD22006 3/8 HOSE BARB VALVED IN-LINE COUPLING INSERT $13.97
I also bought a 3/8 brass elbow to put under the fuel tank barb so the fuel hose
is all in a straight line.
